Hi eberybody,
i have two questions..
The first is:
When i bought the computer there was a rubber pad who was missing... Do you know how can i get it one ?
The second question:
Some times the mouse pad is freezing, the pointer do not move for few secondes... do you know why ?
Thanks by advance for your answers !!!
Sincerely,
Pierre
Hi Pierre,
I am afraid that I am unable to help with your first question. This is going to be very difficult to find. I can only suggest that you try and make one to fit.
Have you checked that the correct drivers are installed for the touchpad? In Device manager, under mice and other pointing devices, this should be identified as an Alps PS/2 Port Pointing Device. If identified as a PS/2 Port Mouse then you need to reinstall the Alps drivers, which you will find in the Drivers folder under Pointing
thanks man for your answer
i would like to know if sony can give me a such rubber pad ?
thanks for your answer
ps, for the pointing i will install the correct drivers...
thanks
thank RICH for all your answers...
i have open a case in the e link, i think it's what you advice yo me ?
Thanks for all and have a nice day...
