Recovery Disks
profile.country.en_GB.title
ritch79
Recovery Disks
Hi
I am going to buy a new Hard drive for my VAIO VGN-AR71M, does anyone know if the operating system from my recovery disks will work with a new hard drive?
Many Thanks.
1 ACCEPTED SOLUTION
Accepted Solutions
rich912
Contributor
Hi ritch79,
Yes the recovery disks should work with a new hard drive as this is the main purpose of the recovery media.
After entering the Recovery Utility select ‘Restore Complete System’ and then skip all other options until the recovery process starts.
Rich
Go n-éirí an bóthar leat
3 REPLIES 3
rich912
Contributor
Hi ritch79,
Rich
ritch79
Many Thanks Rich
rich912
Contributor
You’re welcome and good luck:smileyhappy:
