Vaio GRT DVD rom problem
kumar10
Hi all
I have the sony GRT 815E model laptop purchased one and half year ago. Recently my DVD rom is not working, when i put any DVD its not reading anymore, normal cd works fine only problem with the DVD's.
Can anybody advice me is it problem with the hardware?
thanks in advance
Ramesh
2 REPLIES 2
rich912
Contributor
Hi Ramesh, and welcome to the forum.
Unfortunately this is probably a hardware problem.
However, there are a few things that you can try:
1.Download any available firmware updates for your optical drive from Vaio-Link.
2.Try cleaning the laser lens with a proprietary cleaner.
3.Uninstall the drive in Device Manager, re-boot and let Windows discover and install the device.
If none of the above work it looks as though you need a new drive:smileysad:
Go n-éirí an bóthar leat
profile.country.en_GB.title
kee-lo_
Reinstall Nero if you're using it too, it's ASPI can get messed up
