VGN-AR21B wireless problem
macjjb
hi,
I have problems with my wireless connection.
When there insn't traffic in the connection the adapter goes downn and I lose the conection to internet.
I have to "Repair" the adapter and then the wireless connection runs well until it will gone down again.
could you help me?
thanks
juanjo
1 REPLY 1
Dekesh
check the settings in your router configuration for disconnecting after an idle time. maybe this value is set to a small value and is causing your connection to drop. try increasing the idle time and see if it helps.
