hello,
i have a problem setting the level of the volume, my vaio xl100 is connected to my amp with rca plug at the back of the computer, and when i use the remote to change the volume, it doesn't work.
the volume on the remote seems change the master volume but this one is not the good one.
is there a way to set up on wich out the remote is active ?
thanks
nico
