Where can I buy a replacement wireless keyboard (Model VGP-WKB6GB) for my VAIO entertainment system?
The only place you may get an exact replacement would be from Vaio Support - they sometimes sell stock held for repairs. This would mean using the premium telephone line (35p/min) as your Vaio is outside warranty.
However, any USB keyboard from Amazon or PC World would work - except you would have to use a USB dongle - and this is probably the best way forward. Not as pretty but much cheaper. Have a look at the selection here: -
Thank you for your advice. Can you tell me which premium rate number I need to call? Really confusing trying to contact Sony spares! Cheers
Go to the Vaio After-Sales Support Website here: -
http://www.vaio-link.com/computing/vaio/contacts/index.aspx?l=en_GB
Enter your Vaio's Serial Number
Select Out-of-Warranty Service
Select Phone Support
Good Luck
