My Sony MDR 1000X do not charge
Flumplez
One night I decide to then start charging it, saw the blinking red lights and then went to sleep. When I tried to power it back on in the morning, no luck.
I plugged it back in to charge, and then noticed a sort of a pattern where the red light blinks for exactly 10 times, pauses for about 3 second and then goes off. Shortly after this, the exact same cycle kicks off, 10 blinks, pauses for a few seconds and goes off.
This continues on as long as it is plugged in via USB. Never able to power on. Reset and factory reset subsequently cannot be done either. Tried so many cables.
Tags (1)
1 REPLY 1
Lord_viridis
What power brick are you using?
Lower wattage ones won't kick in the faster charge rate so the headphones will give up trying to enable the charge
