NW-A105 - problems with transferring and playing music files
huxley72
I recently bought a new Walkman and a 1024GB micro sd card to transfer all of my music from my hard drive. Everything was fine for the first 9000 (approximately) songs. I then started to notice that some albums had not transferred, or that when I tried to play music that had been transferred, a message would come up saying "cannot play, the file doesn't exist". These are all files that should be compatible with the player. Also, sometimes songs will be listed in a folder as "unknown", but the artist and albums are correctly titled.
When I select the SD card folder and look under "Music", there are dozens of folders for artists I have transferred to the card, but when I select them, they say "No items".
I bought the Walkman after having problems with a Fiio not updating music correctly, and really thought I had found the right player until these issues started. Can anyone help with this? I'm not even sure if it's a problem with the player itself or the sd card.
Thanks
0 REPLIES 0
