Hi folks,
I have just purchased a Sony NW-A45 Walkman (from Amazon dot com).
Am I only able the recharge the device using the Sony USB-lead connected to my PC? Or can I use a USB-mains-plug such as the model I use to charge my Amazon Fire tablet:
Obviously not having access to a PC (as a charging device) when I am away from home is going to cause issues!
Thanks,
Paul
Hi IamNic,
Will this Amazon charger also be suitable for charging my Sony Headphones please:
Thanks,
Paul
Hello @monsterjazzlicks,
yes, it will.
If your phone uses a USB-charger, this one will work as well.
- Nic
Hi IamNic,
So you do not ever concern yourself over such factors as 'charging-rates', etc?
Thanks,
Paul
no, since universal USB-chargers communicate with the connected device and don't let any more power trough than the device demands.
- Nic
OK, cheers Nic!
