Sony MDR-XB950B1 use mic wired
Hey everyone,
I was just wondering is it possible to use a 3.5mm wire with in line mic to use the Sony xb950b1s wired whilst using the mic on the wire?
Thanks all :slight_smile:
1 REPLY 1
IamNic
Hello @ULTRA_HD_DJ,
you can use the inline-mic on the cable of your choice as long as the device you plug the cable in supports TRRS-connectors (which cables with in-line mic have).
- Nic
