I just bought this headphones and when I connect them via cable they are very powerful but in bluetooth they are not at all. do you know why???
thanks
I just bought the wh1000xm2 noice canceling. when I connect them to a device they are very powerful when I use them. I need to change?
Hello @marcogent,
I first would check the settings in the "Headphones Connect" app to see if any of the settings there might cause the headphones to sound different during bluetooth playback.
- Nic
it depends of your player.
Via bluetooth, some enable separate volume control from player and headphone in this case you have to volume up on both units
