I'm looking to buy the SRS-XB2 so I can use it in the bathroom and when out and about due to its water resistance. I wanted to know if you can change the track of a Bluetooth connected device using the buttons on the unit?
I can't find this information ANYWHERE?
Thank you
Nixk
Hi there
I cant confirm this either. A suggestion - visit a Sony Store or another which sells this product and test it for yourself. Assuming your bluetooth device is portable that is.
http://centresdirect.co.uk/storeinfo.aspx?findstore=1
http://www.sony.co.uk/electronics/wireless-speakers/srs-xb2/buy#dealer-locator-container
This wireless speaker doesn't have skip track button on the unit so you can't do that.
Also take care, SRS-XB2 is IPX5 so it's only splash proof and not water proof. So you can enjoy music while showering but avoid dropping it in the bathtub
