SRS-XB30 - Turn off the lights
Comesi
SRS-XB30: it is possible to Turn off the lights? In overview Sony says: "Manage your music quickly and easily from your smartphone with Sony | Music Center (previously called SongPal). Simply install the app and take control of music, lights and more."
Tags (1)
1 REPLY 1
IamNic
Hello @Comesi,
according to the manual, you should hold the "Extra-Bass"-Button down for 3 seconds to switch off the lights.
- Nic
