WF-1000X device compatibility
MissEliz
I was wondering if anyone has any success pairing the WF-1000X with any other devices apart from iPhone/iPad/Android phones etc ?
I have no problem with my iPad / iPhone where it works with no problems.
I can also pair with my MacBook Pro, however, when watching video, the audio is out-of-sync by about 1/2 second. I know there is some lag with any bluetooth earphones, however the iPhone / iPad seem to adjust automatically for this, whereas the MacBook Pro doesn't for some reason which is odd.
I've also tried pairing with my Onkyo RZ810 A/V Receiver, but that just gets stuck on the pairing stage forever, and therefore doesn't work.
Which devices have you had success with? Is there a compatibility list somewhere?
Thanks for your help
Liz
2 REPLIES 2
Sean_Mc
Moderator
Hi Liz,
Welcome to the community.
There's some advice for pairing your headphones in the manual here. You can also check the support pages here for further tips.
Best wishes,
Ed
MissEliz
Hi Ed,
Thank you for your reply.
I'd already checked in the manual and on the support pages, but I checked again.
I can find nothing that relates to my specific question about using non iOS/Android bluetooth devices.
My question remains! 🙂
Thanks
Liz
