WF-C500 Connects to PC then disconnects after about 30 seconds. My bluetooth drivers are up to date.
My PC is a home build with Asus motherboard with inbuilt bluetooth. They pair after about 3 or 4 attempts then connect, but just disconnect after 30 or 40 seconds. My PC site just next to my legs on the floor.
They work fine with my iphone and ipad.
So not sure on the problem, any help will be appreciated.
1 REPLY 1
SkyNet404
Specialist
Hey there,
I would say try to follow this based on the operating system you're using: https://bit.ly/2XD3P5Y
If it's the same, try it after you initialize the earbuds: https://bit.ly/3PVt0HA.
Hope it helps.
