WH-1000XM3
skunkie01
WH-1000XM3
Hi
so this may have already been asked, I have a KD55XE9005, I’ve just received some headphones WH1000XM3, I can’t for the life of me pair them with the TV the H/Ps work with my iPhone XS, I can pair a Bluetooth speaker with the tv.
any ideas.
6 REPLIES 6
IamNic
Hello @skunkie01,
your TV probably doesn't support the right bluetooth protocol to work with the headphones.
But that is just an assumption.
There are dongles which you can connect to the headphones-audio-jack to connect the headphones to.
- Nic
skunkie01
I believed the Bluetooth protocol is A2DP which the spec sheet for my tv says is there.
IamNic
Hello @skunkie01,
did you delete all bluetooth devices connected to the TV before trying to pair the headphones?
Are the headphones in pairing mode?
- Nic
skunkie01
There are no other items connected, I connect my HK studio 4  speaker to confirm Bluetooth on Tv is working
dazeagle
Won't work. Mine does same thing.
skunkie01
After updating TV software, headphones are working fine.
