annulla
Cerca invece
Intendevi dire:
Wired remote lead for mex-n4100bt
Mattjazz2000
Nuovo
Does any body know where I can get the wired remote lead for the above product in a Renault Kangoo?
thanks
Matt
3 RISPOSTE 3
Anonymous
Non applicabile
Hi there
I believe you may be refering to one of those steering wheel remote controls. If so, you probably need to contact Renault for the actual remote.  However you will probable require an adaptor acording to the manual:
I have looked on the halfords website, and you may probably need both of these:
http://www.halfords.com/technology/car-audio/stereo-fitting-accessories/multistalk-adapter-for-renau...
http://www.halfords.com/technology/car-audio/stereo-fitting-accessories/multistalk-adapter-for-sony
Mattjazz2000
Nuovo
That's the thing thanks. Not sure how well they work?
Anonymous
Non applicabile
Im not sure either, ive never had the opportunity to use one.
