Wireless Stereo Headphone System
12doluc
I have a Samsung Smart Hub television.  At the back is a Microphone slot.  The Stereo mini cable plug does not fit completely into this slot and so I am getting a distorted sound.  Is there a smaller plug that I can add onto the one supplied which will go completely into my tv microphone slot?
2 REPLIES 2
Pascale_F
Moderator
Hi 12doluc
Welcome to the Community.
If you contact
Sony Support about this, they'll be able to assist.
Thanks,
Pascale
IamNic
Hello @12doluc,
I struggle to see how this issue is related to the Sony brand. Which microphone are you using? Is it a Sony microphone? The TV seems to be Samsung as per your last post.
- Nic
