Wx-800ui
Glimmermant21
Wx-800ui
Hi there I currently own a qx-800ui head unit for my car. The buttons on face plate have stopped working and it sometimes comes on then cannot be bothered. I have tried to install the new firmware to update it but unfortunately when the buttons decide to let me in , I can only access the demo on or off in general setting as the dial will not scroll through my other options. If any one can help me please I will be so great full. If not its a head unit heading for the scrap heap lol
4 REPLIES 4
Pascale_F
Moderator
Hi Glimmermant21,
Welcome to the community.
This sounds frustrating. I'll try to find out what can be done about this and get back to you here.
Thanks,
Pascale.
Almou_10
Specialist
Hi Glimmermant21,
I'm not sure if this is a software or hardware issue. Maybe you can try to reset the device using the reset button with a small object ( the one right above the source button).
Hope this helps,
Almou_10
Glimmermant21
Hi there thank you for responding to my dilemma. I have tried the reset many times but no joy, thinking now it's a bin job lol
Win_88
Specialist
A reset was your best bet here, if even that's not having any effect, I think you can try getting it repaired or something. So not all hope is lost.
Win_88
