sony XA won't turn on but led is red when connect charger
nocacad
At night when I'm in a meeting, I wanted to take pictures / documentation of the meeting.
After I took the pictures, which happened to hang my phone lcd white and striped, 1 minute and then automatically restart and ended up stuck in the Sony logo and death can not turn back.
However, when I connect with a charger, led notification indicator is red, lcd keep turning off and not vibrating.
When The power button is pressed, there is no response at all.
I hope here can get a solution to get back to normal.
Thank you
46 REPLIES 46
Emir1
Hero
Hi @Daniel77,
Did you have an opoportunity to try the troubleshooting already posted in the thread? If you have tried it, but it did not resolve the behaviour, then I'm afraid that I can only refer you to have your device sent to service. sad
In order to have your device sent to an authorized service center, I recommend that you get in touch with your Local support in order to be assisted. They are well informed regarding the service routines, warranty terms and consumer laws in your local market. I wish I could assist, but since I am based in the Nordics I am afraid that my market knowledge is limited to the one I'm situated in. sad
@sneezie Unfortunately I am unable to assist you with information in regards to warranty cases, as the terms vary on a market-to-market basis. It would be best to get in touch with your local support team so that they may look into it for you. Slightly_frowning_Face
sneezie
The phone was sent to one of your service centers, they  say it is not economical to repair, so will supply me with an alternative replacement for £140, some warranty that is!!!!!
Emir1
Hero
As I mentioned, even though I would like to - I am unable to look further into local cases or offer any assistance as I do not operate in that specific market. Slightly_frowning_Face I kindly advice you to raise your concern with your local team as they will be best suited to assist you.
nadeem1981
our sony experiaz5p was not working except red led is on.may be it happened due 6 to 8 hours charging through laptop and again charge for 2 or 3 hours through other charger.
as per your seggestion  i have tried power button and volume key up for 10 seconds,
multiple vibration come and red led off , again i switch on the mobile and its working,
thank you so much
#nadeem
Emir1
Hero
Hi @nadeem1981, I am so happy to hear that the device now works again! Slightly_smiling_Face
Please feel free to get in touch if you experience anything else or have any questions!
agusiru
Mi cellphone is not charging, but the red light is on.
I´ve tried with others battery chargers, but happens the same.
Now i can´t even turn it on.  It´s only been 4 months since i bought it. I need an answer- i live in Argentina but i bought it in the US
Maximus661
SNEEZIE
If it is a hardware issue, under UK consumer law the device is covered up to 5 years, which the retailer has the choice of repairing or replacing the device free of charge.
Emir1
Hero
Hi @agusiru, I am sorry to hear about what you are experiencing. Slightly_frowning_Face
Have you tried removing any SIM- and SD cards which you have mounted, and then tried booting the device? You may also try forcing a shut down of the device by holding volume up- and the power button simultaneously until the device vibrates, then try booting it as usual. If it still does not boot, even after attempting a software repair using Xperia Companion, then I am sorry to say that it would be best to have the device sent to an authorized service center. Slightly_frowning_Face
Unfortunately I do not have local information regarding warranty terms and consumer laws in Argentina, therefore it would be best to get in touch with your Local support for some more information.
Let me know how it went!
Themistocles
Thanks! It worked...
Brandy1317
Thanks this help me
