XA1 Ultra - Your Device Has Failed Verification And Will Not Work Properly - Fault
SmileTeam
I have not used my phone for a couple of months. It was working perfectly when I last used it. When I try and switch it on I get the above-mentioned error message along with a message that says Your device will be powered off in 5 seconds.
Any ideas on how to get the phone working properly again?
Thanks.
5 REPLIES 5
Anonymous
Not applicable
Hi there,
Try to perform software repair by the Xperia Companion on the device, you can install it from here
And check this video for the instructions.
SmileTeam
Thank you for your assistance. I will try and see if I can get it working.
SmileTeam
Hi.
I downloaded the software but when I click on the video link to view the instructions it says that the video is not available.
Please help.
Thanks.
profile.country.NL.title
Strampke
Hi @SmileTeam
Have a look at the XA1 Ultra pages where you will find what you're looking for and a lot more.
Anonymous
Not applicable
Hi @SmileTeam
You can check this link for the software repair instructions instead of the video
