Battery Drain since 52.1.A.3.92 update
LeeM21
Hi
Has anyone else had issues with their battery after the update mentioned above?
the phone is losing loads of energy but in the battery usage section it doesn’t account for 60% of the usage (This includes the full device usage).
Any suggestions or ideas outside the usual ‘hold power button down with volume button’ or safe mode would be great, but I’m guessing it might have to be a full factory reset.
cheers,
Lee
3 REPLIES 3
Fahadhabib
Agreed
Plus phone unstable. Keep restarting and not detecting sim card
Fahadhabib
I have move my sim to my old HTC to keep receiving calls amd messages.
Trying to use XZ3 on WiFi which sometimes does not work either due to too many restarts.
Some restarts don't detect sim card, hence WiFi fail to connect as well.
So problems mainly with signal, sim and WiFi in android 10 on xz3...
CosmicTomato
Specialist
Give the software repair a go after an update, just make sure to backup before starting.
