wwhen i first bought it and tested its battery, it was 2980mAh, but not after only more than 1 week, it was down to 2800mAh. IT can't loss capacity so fast, is there some problem with my XZ?
Interesting, do share the link, thanks
You shouldn't assume, I haven't seen any teardown of the Xperia XZ, I could assume it's the same as the Xperia Z series, but that's not accurate, we'll have to wait for someone to take it apart, also, taking a phone apart it's not a big deal, if you want to replace the screen of most smartphones you will have to remove pretty much every component.
Side note, I've done it with different Xperias.
can i reset xz battery
Hi @suarez1121212,
Could you elaborate on what you mean? For which reason would you like to reset the battery, and what do you mean by that more specifically?
Let me know some more details and I'll do my best to assist you!
When checking the battery capacity using *#*#7378423#*#* code i noticed that it was reduced to 2k6 mAh after only MORE THAN 1 WEEK USING. I'm so disappointed with XZ battery so i decide to reset its battery to see if things get better
