[4.3] Battery drain and overheat problem (not sure) [4.3]
KingFox
Hi, i have a problem (or not, im not sure): I recently bought the xperia z smartphone and im running the android 4.3 version. So, i see a battery drain and an overheating "problem" to my phone. Exactly im not sure if its a problem and thats why i messaged here: After 10 mins of disconnected phone from the charge and playing pou my battery went to 96%!!! If u try to calculate it that means about 3-4 hours till 0%!!! Also my phone as a app says going to 40 celsius (all thoose of course when i was playing pou - a game as i said). What about it? Its normal or is a problem?
Screen of the battry usage: https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xap1/t1.0-9/10380771_4266708202325_840429781657479...
Also for thoose are asking, my brightness is on 0%.
P.S: Thats the 2nd time posting that cause staff moved my other post there ( http://talk.sonymobile.com/t5/Xperia-Z-ZL-ZR/4-4-2-Battery-Drain-issue-Workaround-Fix/td-p/697685/pa... ), on a topic about the 4.4.2 version... lol...
12 REPLIES 12
KingFox
Still i think so the problem is not solved.. 5mins on pou and -2%... 😕
KingFox
We are talking about the 4.3 version.... 0.o
KingFox
Finnaly there were no problem guys Slightly_smiling_Face ty
