Battery drain
Goateye1
Battery drain
Running stock Lollipop, 5.0.2
Something happened last week with GooglePlayServices.
It's in the toplist of battery consumption, running up to 20-30%
I have no new apps besides all updates through Play Store...
I have tried to deactivate GooglePlayServices and reinstall without success.
Have not tried facrory reset and is not happy if I need to do it.
Any ideas?
12 REPLIES 12
Uliwooly
That's the reason Google play services battery drain its so high, because of the auto update, but it will go down after a while. enjoy.
Don't forget to check this out
http://talk.sonymobile.com/t5/Software-Updates/Lollipop-New-Features/m-p/955490#U955490
Goateye1
@uliwooly
After a full working day I can say that the problem is more or less solved.
Google Play Services is still running high. Not as high as before and I have reasonable batterylife again.
Thanks!!
Uliwooly
@Goateye
Great to hear that Slightly_smiling_Face
