Fail with stamina mode after upgrade to android lollipop
Raquel05
Hello,
 I have a fail with stamina mode after upgrade to android lollipop
My connections wifi and mobile data are still active and that reduces my battery life
How can i fix it? Should I reinstall android kitkat?
Thanks
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
You can try this: first disable stamina, after go settings-apps-all,scroll down to stamina app and force stop and clear data.Restart.
alexdon
11 REPLIES 11
_alexdon_
alexdon
Raquel05
Thanks very much!!
It works properly now
_alexdon_
Great.
alexdon
ShaggyBamse
I also have trouble with Stamina after lollipop. But mine is not solved with this method. Hoping for a fix soon
_alexdon_
@ShaggyBamse Have you considered a software repair?
alexdon
ShaggyBamse
I can try that one too.. I did a factory reset, but did not work either. My Brother also has the same problem on his Phone, but. The funny thing is that IT shows alot of time left on battery, but never disables WiFi or those things. So I run out of battery after 24h on mixed use and stamnia on. Ultra Stamina works and low battery works. But not normal one:-( I can try repair and report later on or tomorrow:) cheers
ShaggyBamse
Tried the repair, and tre problem presist. As soon as Screen is off, WiFi Bluetooth and the other in stamina dont disable.
_alexdon_
In this case,you should let a sony service handle the device.
alexdon
Bharath_P
I disabled few apps. Activating and then deactivating Ultra stamina mode reverts many disabled apps.
Sony Xperia Z3 : D6653
Lollipop 5.0.2,  Image 23.1.A.0.726
India
