FM Radio problem while listening
Cristian_g
I can't listen the radio while I working with it, but when I switch it to "stand by mode" start hearing. I already read the settings and I can't change it.
The radio worked well, I don´t  know what happen.
Thanks for the help!
1 ACCEPTED SOLUTION
Accepted Solutions
SomeQuickAdvice
Have you activated "ok google" from any screen?
Goto: Settings > Accounts > Google > Search > Voice > "ok google" detection.
If settings is active, try disabling the feature and see if that helps.
5 REPLIES 5
Phy
Legend
Legend
Try booting in safemode and check it again
How to boot on safe mode.
http://talk.sonymobile.com/t5/FAQ/How-to-boot-your-phone-into-safe-mode/m-p/348008#U348008
SomeQuickAdvice
Cristian_g
Thank you! This change solved the problem. Now it run runs well.
mdd
i have a z1, and can't listen to the fm radio. suddendly it starts a noise, and the only thing i can do is change the region. but sometimes i have to continuously change it, sometimes 10 times in 10 minutes.....
baptisteel1
Hello, I have the same problem as mdd which is not a "Ok Google" work around. Xperia Z3C lollipop 5.0
