Usually when I quickly press the power on button I am greeted with my passlock and the time / calander widget at the top of the screen.
Recently however a different widget, such as weather, seems to become the default, and the only way I can seem to get back to the clock widget being default is by removing the other widgets.
I can't beleive this is correct and would appreciate it if anyone could please advise how to make the clock widget the default one seen first when activating the phone.
I have tried things such as swiping a widget to the left / right so the clock widget shows again and switching back to standby, but again when powering up the clock widget is not default.
Any ideas anyone please?
That's the way:
1. lock the screen
2. press "power", lock screen will appear with "default" widget (whatever it is)
3. swipe to the "left" (by the widget) until you see the clock widget, if it is missing, add it using the most left screen with [+] icon
4. tap+hold on the clock widget, then "move" it over this "default" one you've seen
5. make sure the next one to the right is "camera" launcher (clock + camera icon on the right side of this clock)
voila
That's the way:
1. lock the screen
voila
Thanks for the advice, greatly appreciated :smileysmileythumbsup:
