Weak microphone after being in water
ive
Hi when i put my sony z1 Below the water The microphone is weak 10 min. after 10 min he works fine.. Is that normal?
Topic edited by Rickard
1 ACCEPTED SOLUTION
Accepted Solutions
profile.country.RO.title
_alexdon_
Yes,it is normal.Until it is dried up,you will notice a slight loss in output for the speaker and the microphone ability to record.
alexdon
3 REPLIES 3
_alexdon_
alexdon
ive
Ty wm 🙂
_alexdon_
Anytime.
alexdon
