WIFI PROBLEMS WITH LOLLIPOP 5.0.2
AlvaroLS
Since I updated my Xperia Z2 to Lollipop 5.0.2 I have an unstable wifi conection and a low power signal. I've tried all the suggested solutions but the problem persists.
1 ACCEPTED SOLUTION
Accepted Solutions
AlvaroLS
Sorry, it was a hardware problem.
Thaks for answering.
4 REPLIES 4
BeadyEye
That's odd.. Because the lollipop update fixed my wifi issues for the most part.
AlvaroLS
Uliwooly
Could you tell us what is it that you try ?
@AlvaroLS
AlvaroLS
The screen was broken and when repaired, left te wifi antenna out.
