Xperia IV,two headphones same source?
profile.country.SE.title
dsdsds
Is it possible to have two wf-xm4 playing the same source simultaneously connected to xperia iv?
Followed the "share audio guide" but i dont have the same options as presented.
Best regards,ds.
8 REPLIES 8
Piscie
Hey @dsdsds
Have you followed the steps in the manual: https://helpguide.sony.net/mobile/xperia-1m4/v1/en/contents/TP1000786919.html?search=share%20audio?
If so, what settings are missing in your phone? And what is your Android version?
dsdsds
I have android 13,latest updates on all three units involved(phone,wfxm4,wfxm4).
Both pair of headphones are connected and active.
When i follow the instructions i get to that point where im supposed to activate the "audio sharing device option" in the pair of headphones id like to share wich is not present.
Its in row/point 5 in the instructions.
Thank you for assisting me,D.
dsdsds
The option wich isnt present  is called "Add audio sharing device"
My bad in naming it wrong in previous post.
Anonymous
Not applicable
Hey @dsdsds
Can you send a screenshot or a picture showing the options in the menu that you have?
dsdsds
Audio share is activated.
I have no options to activate share audio in neither pair of wf-1000xm4 nor my wh-1000xm4,even tried my Earin A3.
I live in sweden but switched language on the phone for the screenshots sake.
Could it be a region restriction ?
Piscie
Hello @dsdsds, it could be yes. As per the manual, in some regions and countries, LE Audio will be made available through another software update after the Android 13 update.
dsdsds
I suppose its a region thing then,thank you for trying to help me out.
Best regards D.
Piscie
@dsdsds, you're always welcome! Keep an eye on these options after the next software update. Hopefully it will be fixed.
