Hi, I am having issues with my Sony FX3 and have no idea how to fix it.
I am shooting at 4K 25fps and every time I keep getting this small glitches pop up on my footage.
What am I doing wrong? Is this a simple setting that I need to change?
Hey JordanUBT, did you try removing the batteries for two minutes?
What cards are you using for the recording?
