Imaging Edge Post IOS 13
pandsoborn
I can’t transfer photos anymore between my alpha 7II and my iPad or iPhone since upgrading these devices to IOS13. Resetting the wireless password or re-downloading the software does not solve the problem. Looking at the App Store I see that many folk have the same problem. Is there a fix?
1 ACCEPTED SOLUTION
Accepted Solutions
pandsoborn
Hey Nic,
You didn't come back to me!
Fortunately, SONY eventually realised that IOS 13 had happened and that they needed to make modifications to the Imaging Edge Software. A patch was finally released and it now works as it should. I love my Alpha camera but I am seriously concerned about SONY's ability to provide good tech support and customer service.
Regards
Paul
22 REPLIES 22
IamNic
Hello @pandsoborn,
which exact iOS version do you have installed currently?
- Nic
pandsoborn
Hi, I have 13.1.2 running.
IamNic
Hello @pandsoborn,
I will check with support.
- Nic
steven248
Same issue iphone 7 running OS 13.1.2 following the upgrade my Sony RX100 Miii will no longer link to the iphone and I cannot transfer photos across. It has been fine for last year with no problems 😞
Steven
steven248
According to news on imaging Edge Mobile on the 5th October 2019 it states: on iOS13 the settings in imaging edge mobile should have location set to always. However this just resets to ask after selecting this?
Mr______P
Yes same issue. Reinstalled few times, reset Wi-fi, deregister phone from camera nothing seems working.  Come on Sony sort this out. On the app it says iOS 13 user to connect with QR code but where is the QR code to scan?
IamNic
Hello @Mr______P,
on you camera you can either display the SSID+Wifi passcode or a QR-code.
- Nic
pandsoborn
Hey Nic,
Regards
Paul
IamNic
Sorry 😞
Glad to hear it works now.
- Nic
