Partagez votre expérience!
Any suggestions for loading a L-mount lens (NOT Leica M mount) onto a Sony A7riii.
There does nor seem to be any on Amazon but I have a number of L-Mount lenses I wish to use
with Sony A7riii for manual focusing.
If sigma L mount you can pay for mount conversion.
Any other way with adapter that should be only 2mm thin with all electrical contacts and conversions, are not available
Many thanks for your prompt reply. I shall try the conversion route.
