Android 6 (Marshmallow) on 2015/2016 TV's?
profile.country.HU.title
djmickey83
Hello.
During CES I heard a news that Sony will bring Android 6 (Marshmallow) to the 2015 TV lineup.
Link with Video
General News about Marshmallow on Android TV's
These news are from January.
Had anyone heard something new about this?
964 REPLIES 964
Marcd51
Contributor
Hi I just installed that all and it automatically put its own icon with the others on the home screen I did not have to install a sideload app.
Sent from my Sony Xperiaâ„¢ Z5 Smartphone
fether
how did you install aptoide ??? as it dosnt show in google play on my tv i add to download the .apk first then install it through ES explorer but it dosnt show on the home page
kind regards
fether
Garymjh
I installed mine the same as you through an apk via ES and it shows on the home page. It's not really worth it though as the only app Aptoide offers which I can't get on Google Play is showbox. The rest are the usual useless stuff.
Marcd51
Contributor
That's realy personal preference what you may not like or need someone else may want so each to their own..
Try it on you don't like it or need it after you had a play around just un-install it..
Simples..
newbix
I've got a call coming from sony UK office this week.  I just hope it ends my nightmare.
profile.country.HR.title
kinggo01
Contributor
kind regards
fether
You need to sideload Aptoide TV for that, not the regular Aptoide.apk.
fether
cheers for that :ok_hand:
regards
fether
fether
hi all iv managed to change the Developer Options to "at most 3 processes" but when i reboot the tv at any time the settings revert back to the way they were at the begining.
is there any way to stop this ??? please
kind regards
Fether
Garymjh
I googled that a couple of weeks back and the answer is no. It's androids fault not Sony.
fether
ok cheers thanx for the reply
