I'm having an issue using my A95K tv as the centre speaker for an HT-A5000 sound bar - namely crackle / static.
It is not regular, certainly not constant, but crops up from time to time and is quite off-putting.
The tv is connected to the sound bar via HDMI using the e-Arc channel. The sound bar is then connected back to the tv using the 3.5mm jack cable supplied with the tv.
I have contacted Sony Support over this but their trouble-shooting advice only went as far as to suggest unplugging everything. I have read, in a number of places, static if often caused by dirt or dust which can be blown away. I have also read suggestions of using compressed air to do the job but don't know if this sounds like the very most sensible idea!!
Has anyone else had this problem?? Can anyone advise on the dust theory or suggest anything else that might help??
Thank you for the tip.
Im not really optimistic because the repair was done in August or so but I did make the screenshots from my problem that I've posted here and send it per email to the same case number at Sony support.
Now we will see what they'll say.
But as I've said, I'm not to optimistic about the outcome.
I have exactly the same problem with a new Bravia 7 and a A5000 sound bar. Did the motherboard change over sort the problem out. thanks
I did already changed the motherboard because the static noise was noticeable at that time. Now I'm hearing this static noise only when I'm near the speakers, bit again is louder with S-Center function on. I have contacted the Sony Support once again, they have open the repair case, but didn't give me the information about the repair costs. They did gave me the email and number from service company, but after contacting them... No reply!
Now I'm waiting
