Does anyone know if it’s possible to get my ARC upgraded to eARC on my 4 year old Sony TV. I’ve read about firmware upgrades but I don’t know it it’s possible due to the age of my TV. I was looking at getting a Dolby Atmos system until I found out my TV needs eARC. Any help would be greatly appreciated.
Hi stuwillacy,
I don't think so since the hardware isn't capable of handling eARC.
I dont thnk optical has enough bandwidth to support atmos better to connect using hdmi Arc. i thi you nedyo also have cec enabledon thesoundbar and sony sync on the tv
Thanks for your response Peter 👍.
Would you know if I could connect my TV to a soundbar using the optical connection and get the full benefit of Dolby Atmos?
Thanks,
Stuart
