Gray dot on Sony Bravia KD-55X89J display
SOLUCIONADO
profile.country.RO.title
Zoltyka
Explorador
Hi there.
I noticed a gray dot in the middle of display after guarantee expired with 7 days.
Can I do something, or not, or it`t not worth it.
Thanks.
Zoltyka
1 SOLUÇÃO ACEITE
Soluções aceites
daveyh64
Entusiasta
Can you share a picture of this mysterious ray dot.
Ver solução na publicação original
6 RESPOSTAS 6
daveyh64
Entusiasta
daveyh64
Entusiasta
Could you check to see if you have accidentally set the Picture Mode to Game.
Settings button on remote control> scroll right to Picture Mode.
When in Game mode the screen can display a crosshair and one of the options for crosshair
is a gray dot.
Whilst in Game Mode you can switch the crosshair off by pressing the 123/ menu button on the remote and
clicking on Crosshair and set to off.
If you do not want to change any of your Game mode Crosshair settings you can simply change Picture Mode to
Standard or whichever mode you normally watch TV with.
Zoltyka
Explorador
attached
Zoltyka
Explorador
M
aybe looks better.
daveyh64
Entusiasta
Okay so thanks for the picture.
This rules out the TV being in Game Mode.
The darker patch on your screen could have been caused by applying pressure to the screen,
is there  possibility that someone may have pressed the screen while cleaning or moving the TV?
More probably it is an indication of something Calle the dirty screen effect which LCD panel are prone to.
Unfortunately if you are out of warranty there may be very little you can do.
Read about it here,
https://spacehop.com/dirty-screen-effect/
Zoltyka
Explorador
Thank You.
Yes, I think I have dirty screen effect.
Thanks again.
