Partagez votre expérience!
I am extremely disappointed. Despite the fact my TV is not very old it seems I cannot add the Disney Plus app to the menu because it is a non-Android version. I did not know this when I took a subscription out. I would have thought that new apps could be added to my TV a firmware upgrade from Sony. So why has this not already happened before Disney Plus launched?
Disney develop the App, is a Disney's choice...
I just discovered this problem.........is there no way around it?
just buy a chromecast dongle to stream Disney+
Really poor design by Sony. Why have non-Android TV if you are not going to work with major app developers like Disney or Britbox.
We were given a new Bravia x70 as a gift. Not a patch on the ease of use and availability of apps found on Samsung TVs
Hi Irenicon,, you can use an external device like a fire-stick, or casting from your phone if your model supports it.
Me neither very annoying
https://help.disneyplus.com/en-GB/article/disneyplus-android-tv
Bravia is there. Are we saying not Google TV, then?
Whoever created the Discussion doesn't have an Android TV, I hope the others knew what they responded to.
