Info bar everytime adverts are on sky q with Sony Bravia KD49XF7073
M4RC2009
Can any one help this is highly annoying - also does it when loading a 4k movie switches from 480 - 1080 and the then the hi Res but tell me everytime - I don't want to see the info bar constantly
Tags (1)
3 REPLIES 3
EdwinaU
Moderator
Hi there,
Welcome to the community.
We'll look into this and get back to you when we have more information. Maybe another member will have some tips in the meantime.
Best wishes,
Ed
Tenneen9000
Hi M4RC2009,
Sadly, there's no way to disable this info bar entirely. I guess you can press on the "i+/?" button to hide it when it appears.
Best Wishes,
Tenneen9000
LightFoot
Specialist
Hi @M4RC2009   This can be switched off on an Android TV but sadly, as already said it cannot be switched off on a Linux TV (KD-49XF7073). Sony has known about this bug for several years but don’t appear to want to fix it or don’t care.
If you are willing to put up with degraded audio, change the Audio output of your Sky Q box to Normal. This means the audio format doesn’t change between SD, HD and UHD or even when adverts appear which triggers the Info Banner. Try a search on “Other TVs” for Info Banner on Linux TVs.
