Делитесь своим опытом!
KD-65X8509C bought within the last week
I have the TV's IR Blaster setup to control a BSkyB Sky+HD box, and most controls work great. However, the UP/DOWN/LEFT/RIGHT navigation buttons work, but always sends 3 occurrences of UP, DOWN, LEFT, or RIGHT instead of just one occurrence.
So, for example, when navigating the Sky+HD box list of recordings, pressing down skips down 3 recordings, making it impossible to select the recordings in-between.
Is there some way to update the IR blaster database to correctly only send 1 occurrence of LEFT, RIGHT, UP, or DOWN when that button is pressed? Or is there any other solution to this problem, that will make the UP/DOWN/LEFT/RIGHT buttons behave correctly?
Решено! Перейти к решению.
Hi I've set-up my IR Blaster with my Sky Box everything works well accept in the guide menu, the direction keys skip 3 boxes at a time. I done a factory reset as suggested. But it didn't work, any other ideas?
Sony support told me the same but once the TV software upgrade was in place the problem was fixed. Do check the software level on your TV there have 4 or 5 updates since the problem was fixed.
I hope you get the issue resolved.
Nick
I recently got the KD-55XE9005 and have the exact same issue as OP, software is up to date. The only way to get scrolling to work is when pressing the button to scroll, keep your finger on the button for a second rather than 'click' it, that way it will move one choice at a time rather than three. Not ideal, but it seems to work.
I have a question for those who have managed to get the IR blaster working with their Sky HD box.
Does the IR blaster issue power on/off commands to the Sky HD box? Or is this handled by HDMI CEC?
Also has anyone managed to get the IR blaster working with the Sky Q system?
Can you control the Sky Q box from the Sony Remote? (Using the IR blaster?)
If so, what manufacturer / STB model number are you using? I have tried all the "BSkyB" STB codes and none of them seem to work.
Did anyone find a way of accessing the Sky Planner / Recorded programs (i.e. like pressing the "Sky" key) directly from the Sony remote? I know you can mimic it from the "Action Menu" but this is quite frustrating.
Anyone?
