I like this television, but the Android system i dont, i do have a Android tablet which is okay.
I dont like the the menu systems.
IR Blaster, just wont pair with my devices, i have read all the help guides.
Mirroring sees my TV but wont connect.
From what i can see, unless everthing is connected to the sony and you have "Bravia", enabled devices, that is where the problems begin, I have a Denon X7200WA, AVR-Reciever which cost over £3,000,everything is connected to it,my previous TV was a Pansonic 50" Plasma TV, which had no problem working with the reciever.
I have spoken to the manager of the store where i purchased the Sony from and explained all of the above to him, he has offered to exchange it for me for another, "OLED TV", as i have been a customer with them for many years.
I would hope someone from Sony or the forum can help me.
Hi @Helius82,
an IR-Blaster does not pair in any way. It just sends commands via infrared (just like a normal TV remote).
Screen mirroring works via WiFi and needs pairing.
- Nic
Hi Nic,
Thanks for your reply.
I printed the instructions, from the Sony-help guide.
Connecting an IR Blaster (IR Blaster compatible models only).
IR compatible models may not be available depending on your model/country.)
It searches but will not find my set top box, or AVR Reciever.
I think that is the problem, because i have everything connected to my reciever acting as a hub,it seems, if the devices, are not connected to the,A1, nothing will work.
Mirroring.
I went to PC World last Saturday and spoke to the Sony rep as i was going to buy the Chromecast ultra, £70, he sugested i download Allcast or something similar from the playstore.
I will give it a try.
Hi @Helius82,
doesn't the A1 have Google-Cast pre-installed?
Every Android TV normally has this, which would save you the money for a Chrome Cast.
- Nic
It has in the apps,but i cant get it to work.
If i could find the settings to set it up or activate it i would be able to.
Just a thought on the IR Blaster,if i go into Network and Sharing Center>Manage Wireles Networks that use (Wireless Network Connection) , and register, IR Blaster would that work.
