KD-49XD8305
Johnny96
KD-49XD8305
Hi, I have the KD-49XD8305 currently on a wall mount and I’m looking to have it free standing on a unit. I have the stand that came with the tv still in its original sealed packaging but I’m missing the two necks and screws for the stand. Can anyone advise where I might be able to source these or even know of a part number for them and what the cost could be for them. Thanks.
9 REPLIES 9
Marino.Manolo
Marino.Manolo
Johnny96
Thanks for your reply, had a good Google search using the information you supplied but still can’t find them anywhere.
Marino.Manolo
Maybe an Assistance...
Or even if you search, you will find quite high prices.
https://alfatec.co.uk/professional-displays/accessories/sony-bracket-458119701-stand-necks-assembly-...
Have you tried on eBay?
If you can't find it, you can divert to a table stand that uses the holes for the VESA predisposition of your TV, the same ones you used for the wall bracket.
Johnny96
Thanks once again for your reply, those necks are extremely expensive. There seems to be lots of necks available just not for the model I have. Out of interest do you know if there is any difference between my model KD-49XD8305 and the KD-49X8305C as I have been able to find necks for this one. Thanks
Marino.Manolo
In a Service Manual of KD-49X8005C, X80C Series, I've not found the exatct Service Manual for the X8305C (with a disassembling), the Necks are calle only "NECK" whitout a Code Number...
Marino.Manolo
Unfortunately from the drawing, compared to the image, it seems that the "recess" at the top is different, which would prevent it from being inserted all the way.
Sorry for my bad english...
Johnny96
Thank you, you have been very helpful. I may just need to look at a universal stand if I can’t find the necks at a suitable price.
Anonymous
Not applicable
You really need to be careful when using a 3rd party stand as it can damage the TV, and might not even fit.
So I would recommend giving it another shot to find the stand for that TV.
