Hello
I was wondering if you could give me some advice. I have the above TV and I currently use an Astro A50 Gen 3 wireless Headset when using my PS4, Xbox One. I also watch tv through it by connecting the optical lead to the optical out on the TV.
The first question is what are the best audio settings on the TV to use? Also should I switch to “Audio System” or keep using “TV Speakers” and does it make any difference? If there any settings I need to put in place to make sure I don’t get any lip sync issues?
I am not great with settings so I thought I would ask the experts!
Many thanks
Jon
If you set the audio to external audio you switch off the internal speaker and enable multichannel audio on the optical lead (if your headset could make advantage of it I really don't know)
Hi Rooobb
Thanks for coming back to me and I appreciate your assistance. I am using optical at the moment and I will do as you have suggested.
I am due to receive the PS5 in the next few weeks which does not support optical so I will have to go the HDMI route and just wondered if it makes any difference? Also i could do with some advice on the following and which ones to use: -
Headphone/Audio Out
- Headphone
- Audio out (fixed)
- Audio out (variable)
- subwoofer
Is PCM the best setting to use when using headphones?
Apologies in advance for the number of questions but I just want to get everything setup correctly.
Many thanks
Jon
I'll try to answer your question...;)
Hi Rooobb
That is a great help thanks.
This is the Headset I use but although it has Dolby capabilities I am not sure whether it is technically still classed as stereo.
https://www.astrogaming.com/en-gb/products/headsets/a50-gen-4.html#tech-specs
It was easier with a commodore Amiga back in the day! Lol
