Problem with BBC iPlayer on AF9 after firmware update
jukbee
Hi all,
I'm having a problem with built-in BBC iPlayer app on my AF9 after the latest firmware update. As you can see in the attached pictures here, it suffers from these small horizontal lines making it unwatchable. The lines appear upon opening the app and disappear when app is closed.
Anyone knows how to fix this? I tried clearing cache and restart the tv but no good.
Thanks!
1 ACCEPTED SOLUTION
Accepted Solutions
jukbee
Found the culprit. Turning off "Force GPU rendering" under "Developer Option" fixed the problem.
Phewwww...
2 REPLIES 2
jukbee
Phewwww...
Anonymous
Not applicable
I'm glad to hear you found the culprit. Thanks for sharing the solution with us!
