My Sony Bravia KD-43XE8396 after a recent software update 2 days ago will no longer connect to the internet. The T.V is connecting to the Network with no problems and connects to the internet for a second and then says - no internet. I checked my internet router with a Cat 6 cable and with a direct connection it connects to the internet with no problems. I have looked through all the threads on the sony website and returned the TV to a factory reset but still no joy.
Two other questions
(1) for date and time - which is the correct option ( i have picked automatic date and time)
(2) my keyboard on the T.V or internet explorer is coming up with 5 different options for e when you pick it and the same for i
Any help to solve these issues would be great.
Thanks Doyler23
Well as I said I tried the ipv6 disable on my father's TV and I think it also fixed his issue .I did say to him ring me if it didn't work and at the moment I haven't had a call I will ring him in a few hours to see and update here if it did cure it..and his TV was brand new straight out the box an xg819 .
Just spoke to my father and he confirmed that it solved the issue... surely must be a bug in the software
Thanks, that solved the problem back on Wi-Fi again, by turning off the IP6 setting in the router as you said.
I am also having a problem with the virtual keyboard on the internet explorer browser it is coming up with 5 different options for the letter e (e.g the different versions for e used in french - and no option for the letter e) when you pick it and the same for the letter i ( and no option for the letter i).
What is the correct option for the keyboard settings - mine is currently set as - Gboard is this the correct setting?
(I cannot log in to amazon account to get into my amazon prime account)
