Problems with Android 8.0
Sterling77
Hi guys.
Who can tell me if Sony intends to resolve the problems that drag the 8.0 and when it arian please?.
Because if they do not have the intention, they should unlock again, see 7.0, because this update has made the TV a *****, Slower, I can not navigate because I do not see the internal keypad, the previous installed apk and those from now do not work, it does not let me use the SmartTv Remote Control One-flick Touch Pad and the home theater does not work is not singronized as I did it with 7.0.
Can you please tell me if you are going to update these problems or if there is a way to go back to 7.0?
THKS...
3 REPLIES 3
Sterling77
Hi guys.
Because if they do not have the intention, they should unlock again the 7.0, because this update has made the TV a *****, Slower, I can not navigate because I do not see the internal keypad, the previous installed apk and those from now do not work, it does not let me use the SmartTv Remote Control One-flick Touch Pad and the home theater does not work is not singronized as it did it with 7.0.
Can someone from sony address this issue with the firmware update rendering old units useless 7.0? is there a way to do a rollback?
rooobb
A New  release is planned  very soon but nothing that you highlight was ever post as a bug
Oreo is faster even if not by that much compared to nougat.
The internal keypad is disabled only if you have a physical keyboard connected to an USB port
Do not know what apk you cannot find anymore installed but you cannot ask Sony for supporting something that you do at your own risk
The same goes with the one flicker remote that is not supported officially by any oreo enabled TV
Do not know what syncing problem you have with the sound bar but if it is connected via hdmi arc probably will be addressed by the new release
LightFoot
Specialist
Please ignore, finger trouble.
