Sony ag8 tv won’t switch on after being on standby for a while
Powerfulsteve
  1. After the recent update done on my tv I have found not being able to turn it on after being on standby for a period of time, I end up pulling the power lead out for 30 seconds then reconnecting it and the tv will come on. just done a factory reset so I’m hoping it will fix it
any other suggestions?
1 ACCEPTED SOLUTION
Accepted Solutions
Powerfulsteve
Yes by doing a factory reset it has sorted the issue out
Thanks
Steve Heaton
6 REPLIES 6
Sean_Mc
Moderator
Hi Steve,
If you have performed the reset, this should have hopefully resolved this issue for you.
Can you let me know the outcome?
Best wishes,
Sean
Powerfulsteve
Thanks
Steve Heaton
David.eyres
Hi all.
sorry for being late to the party. I’m having the same issue since updating my AG8 tv to the latest software (Feb 2020). I have tried the factory reset. Set everything back up again. But every time I turn the tv off after viewing it then refuses to turn back on . You have to kill it at the wall for a minute and then wait for it to restart. It’s incredibly frustrating
Tags (4)
Powerfulsteve
Have you tried turning the power saving on to low? Mine did it again recently and after turning it onto power saving mode low it seems to fix it
Thanks
Steve Heaton
Powerfulsteve
If you have done the factory reset then try turning the power saving mode onto low and try that, I have done that and it seem to have fixed it at the minute
khallergard
@David.eyres  have you tried removing USBs before switching to standby?
