Why am I unable to accesses YouTube on my TV?
Hi there,
I'll check into this for you you and get back to you.
Welcome to our forums.
Best wishes,
M
Can you please give us a bit more info on the problem. Was it working before? Do you see any errors?
Thanks,
Drew
Are you able to perform a factory reset to see if that fixes the issue?
Thanks,
Drew
