annuleren
Resultaten voor
Zoek in plaats daarvan naar
Bedoelde u:
Sony kd-50x85j in combination with ht-g700
profile.country.NL.title
slaan1974_1
Lid
i would like to know what the best solution for the following use case;
i would like to play random music on the BT of the soundbar, this works fine , but if you turn on the TV it automatically recognises the soundbar and takes lead over the music. with other words the music is gone.
There is a setting that you turn it off on the soundbar but this turns everything off. i would like to turn on the soundbar manually when required and not always use the full soundbar in our opinion the sound from the tv is good enough for normal TV and also saves on the energy bill.
i am currently using a hdmi 2.1 cable between both systems or should I use the old 1.2 cable as this does not have the arc/earc features.
let us know what the best solutions are here, thanks
2 ANTWOORDEN 2
pa3eia
Dit is het Nederlandse gedeelte van de Sony Community, met als voertaal Nederlands.
Sony UK
73's
Thanks about the Kudos!!!
pa3eia
We gaan hier verder in het Nederlands.
73's
